York FLT Rear Chain Drive Kit - V-Twin 19-0277 - Big Twin 1986-1999
by York
$259.99
2079 ENTRIES 🎟️
$259.99 - $259.99
$259.99
2079 ENTRIES 🎟️
Transmission sprocket conversion kit is used to convert belt drive models to chain drive
Kit features a 120 link chain. Includes 24 tooth front sprocket and 48 tooth rear sprocket to achieve stock gearing. *NOTE: 48 tooth sprocket features a 1.990 inner diameter. Converting to chain drive easier and less work than changing a broken belt as the swingarm does not have to be removed. Save time and money with this conversion. Chain breaker and puller supplied to facilitate cutting and installing the chain.
  • Other Ratio Sprockets Available Separately: 47 Tooth Rear Sprocket = 2.5% Over Drive Top Speed. 48 Tooth Rear Sprocket = Stock Belt Ration
  • 49 Tooth Rear Sprocket = 4% Deeper (Faster Acceleration). 51 Tooth Rear Sprocket = 6% Deeper (Faster Acceleration)
1986-1999 FLT
