Rear Pulley Brake Disc Spacer Polished 1/2 Thickness - York D26-0138-S050 - Big Twin 0+
by York
359 ENTRIES 🎟️
359 ENTRIES 🎟️
York #: D26-0138-S050
Polished alloy 1/2 inch thick rear pulley rotor spacer is ideal to get belt pulleys or chain sprockets in line and features 7/16 inch bolt holes.
These spacers can also be used as a disc spacer. Spacer can be machined down to the next size under without having to worry about the spigot alignment when you machine the face of the spacer down to the desired thickness. *NOTE: Inner Diameter is 2-1/4 inch to fit 2000-UP rear hubs on FX FL and XL models.
  • Inner Diameter: 2.25 inches
