Jims Fuel Pressure Test Gauge Tool - Jims 955 - Twin Cam 2006+
by Jims
Original price $609.99 - Original price $609.99
$609.99
6099 ENTRIES 🎟️
$609.99 - $609.99
$609.99
6099 ENTRIES 🎟️
Jims #: 955
Jims fuel pressure test gauge tool includes the hose connectors and fittings to safely perform a fuel pressure test. Detailed instructions are included. Tool is a must have as 90% of Big Twins have electronic fuel injection.
Jims fuel pressue gauge tool should be used if a customer is experiencing hesitation under acceleration loss of power back firing through the intake poor fuel economy stalling out or if the engine will turn but not start. This tool is easily installed inline with the motorcycles fuel supply system. Jims fuel pressure test gauge tool will provide you all the necessary hose connections and fittings to safely perform a fuel pressure test in about the same time it takes to change a set of spark plugs. This test gauge tool is for use on all Harley Davidson models using electronic fuel injection including V-Rod models.
  • Fuel testing should be done with engine running with this tool.
2006-2017 FLST
2006-UP FLT
2006-2017 FXD
2006-2017 FXST
