23 Tooth Transmission Sprocket Kit - York 26-0125-23 - Big Twin 0+
by York
$79.99
799 ENTRIES 🎟️
$79.99 - $79.99
$79.99
799 ENTRIES 🎟️
York #: 26-0125-23
This 23 tooth transmission sprocket conversion kit with a.500 offset for 530 chain includes the wheel spacer for converting a belt drive to a chain drive. For 5 speed models.
NOTE: Remember a larger sprocket on rear means more torque (geared down) and a larger front sprocket means higher gears more top end.
  • Spacer In. Diameter: 2.12 inches
  • Spacer Thickness: 0.202 inches
  • Suggested to use with Hex Flange Sprocket Nut Black.
