Countershaft Sprocket 17 Tooth - York 2035-41 - OEM 35204-41
by York
$54.99
439 ENTRIES 🎟️
$54.99 - $54.99
$54.99
439 ENTRIES 🎟️
York #: 2035-41 · OEM #: 35204-41, 2035-41
Includes one 17 tooth countershaft sprocket.
Sprocket shaft seal must be pressed into the sprocket. Check that any burrs or molding flashes are removed from the outside diameter edge of the seal prior to installation. It is recommended that the seal be positioned on the transmission shaft prior to installing the sprocket. This will make seal installation easier. *NOTE: The seal is installed.
1941-1973 G
1938-1952 WL
