Jims 3-Hole Crank Pin with 180° Oiling - Jims 23961-80AS - Big Twin 1981-1998
by Jims
$149.99
$149.99
$149.99
1199 ENTRIES 🎟️
$149.99
$149.99
$149.99
1199 ENTRIES 🎟️
Jims #: 23961-80AS
Crank pin is made of 8620 steel with heat treating 60-62RC to a case depth of.100. A special 180° oiling design helps lubricate the bearing diameter.
Crank pin has an outer diameter of 1.2495 inch. Order nuts separately.
| 1981-1984 | FL |
| 1986-1998 | FLST |
| 1981-1998 | FLT |
| 1981-1984 | FX |
| 1991-1998 | FXD |
| 1982-1994 | FXR |
| 1984-1998 | FXST |
