62 Tooth Clutch Drum Starter Ring Gear Welded-On - V-Twin 18-3640 - OEM 33162-67 - Ironhead 1967-1980
by York
$54.99
439 ENTRIES 🎟️
$54.99 - $54.99
$54.99
439 ENTRIES 🎟️
OEM #: 33162-67
62 tooth clutch drum starter ring gear is weld-on type. Replacement ring gear for stock clutch drums. Bevel edge is for welding (outside) teeth side.
Starter ring gear installs with beveled side of the teeth towards the starter gear to help engage the starter drive. *NOTE: Your existing clutch drum must have the OEM Ring gear welded in placed V-Twin motor shop offers this service.
  • Inner Diameter: 6-1/2 inches
  • Outer Diameter: 7-7/8 inches
  • Thickness: 3/8 inches
  • Suggested to use with XL York Electric Start Kit.
1967-1980 XL
