84 Tooth Clutch Drum Ring Gear Kit - York 148179 - Evolution 1994-1997
by York
$139.99
1119 ENTRIES 🎟️
$139.99 - $139.99
$139.99
1119 ENTRIES 🎟️
York #: 148179
Kit includes a 84 tooth ring gear with mounting hardware and a 10 tooth pinion gear.
This ratio allows more RPMs for easier starting. The heavier teeth configuration is less susceptible to wear or breakage by converting the 102 tooth ring gear to 84 tooth. The center hole to center hole measures 7-1/4 inch.
  • Inner Diameter: 6.45 inches
  • Bevel goes towards the starter gear so that it can engage easier.
1994-1997 FLST
1994-1997 FLT
1994-1997 FXD
1994-1997 FXST
