York Softail Rear Chain Drive Kit - V-Twin 19-0179 - Twin Cam Softail 2000-2006
Conversion kit includes everything needed to convert the belt drive system to heavy duty 530 chain drive. Stock ratio is supplied with a 22 tooth front sprocket and a 51 tooth rear sprocket.
This kit is for a stock size rear tire. Chain will have to be cut to length breaker and master link included. *NOTE: Use existing pulley spacer behind the transmission 22 tooth sprocket. *NOTE: 530 120 link heavy duty york chain included with chain breaker so installer can cut to chain to desired length for each application. When using a 21 tooth front sprocket: 48 tooth rear sprocket = 4% deeper (faster acceleration) 49 tooth rear sprocket = 6.5% deeper and 51 tooth rear sprocket = 10.5$ deeper. When using a 22 tooth front sprocket: 48 tooth rear sprocket = 2.5 inch overdrive (more top speed) 48 tooth rear sprocket - stock belt drive ratio 49 tooth rear sprocket = 4% deeper (faster acceleration) and 51 tooth rear sprocket = 6% deeper.
- *NOTE: Includes inchDiamondinch standard 530 x 120 link drive chain with master link. Installer must cut to desired length. Use chain puller to bring to length then brak at link.
| 2000-2006 | FLST |
| 2000-2006 | FXST |
