Transmission Sprocket 24 Tooth - York D26-0008-24 - Big Twin 0+
by York
$79.99
$79.99
$79.99
639 ENTRIES 🎟️
$79.99
$79.99
$79.99
639 ENTRIES 🎟️
York #: D26-0008-24
24 Tooth Transmission Sprocket with a.250 offset and 2 holes. For 5 speed models.
Allows the installation of a 180 tire without transmission offset..900 inch offset is the maximum offset without any modification to the stock inner primary. The center hole sprocket side down measures 0.875 inch.
- .200inch offset is measured from the back side of the teeth to the back side of the sprocket excluding the flange.
- .715inch offset is measures from the center line of the teeth to the top of the flange on the back side of the sprocket.
- Suggested to use with Pulley Indexing Flange Nut.
