Rear Sprocket Chrome 48 Tooth - York 16458
by York
$84.99
$84.99
$84.99
679 ENTRIES 🎟️
$84.99
$84.99
$84.99
679 ENTRIES 🎟️
York #: 16458
5-Spoke rear sprocket with a chrome finish. Sprocket is 48 tooth with a 9.8mm offset.
The inner diameter of the sprocket measures 2.25 inch. *NOTE: Remember a larger sprocket on rear means more torque (geared down) and a larger front sprocket means higher gears more top end.
- Inner Diameter: 2-1/4 inches
- Offset is measured from the sprocket bolt mount surface to the center line of the teeth.
