24 Tooth Transmission Sprocket - York 26-0007-24 - Big Twin 0+
by York
$74.99
599 ENTRIES 🎟️
$74.99 - $74.99
$74.99
599 ENTRIES 🎟️
York #: 26-0007-24
This 24 tooth transmission sprocket with 2 holes and a.900 inch offset allows the installation of a 180 tire without transmission offset. For 5 speed models.
A.900 inch offset is the maximum offset without any modification to the stock inner primary.
  • Outer Diameter: 5 inches
  • Sprocket Thickness: 1-1/2 inches
  • Tooth Thickness: 1/4 inches
  • Height: 1-3/8 inches
  • Bottom I.D.: 3-7/8 inches
  • .900inch offset is measured from the back side of the teeth to the back side of the sprocket excluding the flange.
  • 1.350inch offset is measured from the center line of the teeth to the top of the flange on the back side of the sprocket.
  • Suggested to use with Pulley Indexing Flange Nut.
