24 Tooth Transmission Sprocket - York 26-0006-24
by York
$79.99
639 ENTRIES 🎟️
$79.99 - $79.99
$79.99
639 ENTRIES 🎟️
York #: 26-0006-24
This 24 Tooth transmission sprocket has 2 holes and a.810 inch offset. For 5 speed models.
It allows the installation of a 180 tire without transmission offset. The maximum offset without any modification to the stock inner primary is.900 inch.
  • Height: 1-1/2 inches
  • Inner Diameter: 3-29/32 inches
  • .810inch offset is measured from the back side of the teeth to the back side of the sprocket excluding the flange.
  • 1.236inch offset is measured from the center line of the teeth to the top of the flange on the back side of the sprocket.
  • Suggested to use with Pulley Indexing Flange Nut.
