York M8 Rear Chain Drive Kit - V-Twin 19-0287 - Twin Cam Touring 2017+
Transmission sprocket conversion kit is used to convert belt drive models to chain drive. For M8 models.
Includes 24 tooth front sprocket and 51 tooth rear sprocket to achieve stock gearing. *NOTE: Sprocket adapter assembled with non-ABS bearings. Converting to chain drive easier and less work than changing a broken belt as the swingarm does not have to be removed. Save time and money with this conversion. Chain breaker and puller supplied to facilitate cutting and installing the chain.
| 2017-UP | FLT |
