York FLT Rear Chain Drive Kit - V-Twin 19-0279 - Twin Cam Touring 2009-2016
Transmission sprocket conversion kit is used to convert belt drive models to chain drive.
Kit features a 120 link chain. Includes rear hub cushion conversion 24 tooth front sprocket and 51 tooth rear sprocket to achieve stock ratio gearing. *NOTE: Sprocket adapter assembled with non-ABS bearings. Converting to chain drive easier and less work than changing a broken belt as the swingarm does not have to be removed. Save time and money with this conversion. Chain breaker and puller supplied to facilitate cutting and installing the chain.
- Suggested to use with Transmission Sprocket 24 Tooth.
| 2009-2016 | FLT |
