Transmission Sprocket 23 Tooth - York 26-0006-23
by York
519 ENTRIES 🎟️
519 ENTRIES 🎟️
York #: 26-0006-23
23 Tooth transmission sprocket with 2 holes and an.810 inch offset. For 5 speed models.
Allows the installation of a 180 tire without transmission offset..900 inch offset is the maximum offset without any modification to the stock inner primary.
  • .810inch offset is measured from the back side of the teeth to the back side of the sprocket excluding the flange.
  • 1.236inch offset is measured from the center line of the teeth to the top of the flange on the back side of the sprocket.
  • Suggested to use with Pulley Indexing Flange Nut.
