York FXD Rear Chain Drive Kit - V-Twin 19-0677 - Big Twin 1995-1999
by York
SKU 19-0677
$289.99
$289.99 - $289.99
$289.99
FXD rear chain and sprocket kit for 5 speed models. Supplied with all sprockets to provide stock gear ratios.
Kit includes the following: sprockets and chain rear chrome sprocket rear 51 tooth sprocket with offset front 23 tooth sprocket.750 inch offset and a 120 link chain. *NOTE: Chain must be cut to length kit includes a chain breaker tool. Cut chain to fit with the wheel and axle all the way forward for maximum adjustment as the chain wears in. *NOTE: 530 120 link heavy duty york chain included with chain breaker so installer can cut chain to desired length for each application.
  • *NOTE: Includes inchDiamondinch standard 530 x 120 link drive chain with master link. Installer must cut to desired length. Use chain puller to bring to length then brak at link.
1995-1999 FXD
