York FLT Rear Chain Drive Kit - V-Twin 19-0281 - Twin Cam Touring 2000-2006
by York
SKU 19-0281
$269.99
$269.99 - $269.99
$269.99
Transmission sprocket conversion kit is used to convert belt drive models to chain drive
Kit features a 120 link chain. Includes 24 tooth front sprocket and 48 tooth rear sprocket to achieve stock gearing. *NOTE: 48 tooth sprocket features a 2.25 inner diameter. Converting to chain drive easier and less work than changing a broken belt as the swingarm does not have to be removed. Save time and money with this conversion. Chain breaker and puller supplied to facilitate cutting and installing the chain.
  • Other Ratio Sprockets Available Separately: 47 Tooth Rear Sprocket = 2.5% Over Drive Top Speed 48 Tooth Rear Sprocket = Stock Bel Ration
  • 49 Tooth Rear Sprocket = 4% Deeper (Faster Acceleration) 51 Tooth Rear Sprocket = 6% Deeper (Faster Acceleration)
2000-2006 FLT
