York Electric Start Oil Tank Raw - V-Twin 40-1429
This wrap around four quart center fill oil tank is for installation in rigid frames (stock replica or custom) with 4 speed transmissions with the York electric start kits. Tank includes a screw in dip stick cap.
Clamps for battery must be fabricated. The battery will require spacing to secure in place by the builder. *NOTE: Batteries must be ordered separately. Electric start uses Anti Gravity 12 Volt 16 Cell Battery. *NOTE: The battery compartment measures 114mm x 114mm x 146mm. *NOTE: Requires an oil tank base for installation on York electric start kits. Mount plate allows extra space for electric starters. The plate allows for mounting on 1936 models. *NOTE: Oil tank will fit 1941-1957 FL rigid frames when an electric start system is installed. Tank accepts standard drain plug and is the center top fill type.
- Height: 5-5/8 inches
- Width: 10 inches
- Depth: 8-5/8 inches
- Suggested to use with Chrome Oil Tank Rear Fender Mount Bracket for rigid applications.
- Suggested to use with Anti Gravity 12 Volt 16 Cell Battery.
- Required to use with Oil Tank Base Black.
- Suggested to use with York Electric Starter Kit.
- *NOTE: Tank has a left side chain guard tab and may have to be removed on some installations.
- *NOTE: Tank body is full height. The rear bracket is raised up to accept base plate to allow clearance for the York electric starter.
| 1936-1952 | EL |
| 1941-1957 | FL |
