York Electric Start Oil Tank Black - V-Twin 40-0616
by York
SKU 40-0616
$229.99
2299 ENTRIES 🎟️
$229.99 - $229.99
$229.99
2299 ENTRIES 🎟️
This wrap around four quart center fill oil tank is for installation in rigid frames (stock replica or custom) with 4 speed transmissions with the York electric start kits. Tank includes a screw in dip stick cap.
Clamps for battery must be fabricated. The battery will require spacing to secure in place by the builder. *NOTE: Batteries must be ordered separately. Electric start uses Anti Gravity 12 Volt 16 Cell Battery. *NOTE: The battery compartment measures 114mm x 114mm x 146mm. *NOTE: Requires an oil tank base for installation on York electric start kits. Mount plate allows extra space for electric starters. The plate allows for mounting on 1936 models. *NOTE: Uses stock threaded oil lines. *NOTE: Oil tank will fit 1941-1984 FL frames when an electric start system is installed. Tank accepts standard drain plug and is the center top fill type.
  • Height: 5-5/8 inches
  • Width: 10 inches
  • Depth: 8-5/8 inches
  • Suggested to use with Chrome Oil Tank Rear Fender Mount Bracket for rigid applications.
  • Suggested to use with Anti Gravity 12 Volt 16 Cell Battery.
  • Required to use with Oil Tank Base Black.
  • Suggested to use with York Electric Starter Kit.
  • *NOTE: Tank has a left side chain guard tab and may have to be removed on some installations.
  • *NOTE: Tank body is full height. The rear bracket is raised up to accept base plate to allow clearance for the York electric starter.
1936-1952 EL
1941-1957 FL
