York Compensator Lock Nut Kit - V-Twin 19-0487 - Twin Cam 2009-2013
by York
SKU 19-0487
$69.99
$69.99 - $69.99
$69.99
York compensator lock nut kit includes a lock plate and lock tabs which secure the nut to the sprocket retainer so that the compensator nut and lock plate bolts does not come loose.
Similar to the bulletproof transmission pulley mega nut this lock kit is so that the compensator nut will not come loose and cause unnecessary unsafe and expensive damage. Kit includes 5 pieces; one long hex nut one lock tab washer one lock ring and two hex screws. *NOTE: For use with 34 Tooth Compensaotr Sprocket Kits only.
  • Suggested to only use with Compensator Sprocket Kit 34 Tooth.
2009-2013 FLHXX
2012-2013 FLST
2011-2013 FLT
2012-2013 FXD
2012-2013 FXST
