Transmission Sprocket 24 Tooth - York 26-0005-24
by York
SKU 19-0489
York #: 26-0005-24
24 tooth front transmission sprocket with 2 holes and a.500 inch offset. For 5 speed models.
Allows the installation of a 180 tire without transmission offset..900 offset is the maximum offset without any modification to the stock inner primary.
- .500inch offset is measured from the back side of the teeth to the back side of the sprocket excluding the flange
- .940inch offset is measured from the center line of the teeth to the top of the flange on the back side of the sprocket.
- Suggested to use with Pulley Indexing Flange Nut.
