Transmission Sprocket 24 Tooth - York 191322 - Twin Cam 2006-2017
by York
SKU 19-0610
York #: 191322
Offset 24 tooth transmission sprocket with 2 holes is for 6-speed models.
This sprocket features a 1/2 inch offset for installing a slightly wider tire without needing to offset the primary or transmission. The thickness of the sprocket in the center splined area is 3/4 inch.
- Suggested to use with Pulley Indexing Flange Nut.
| 2007-2016 | FLST |
| 2006-2017 | FXD |
| 2007-2016 | FXST |
