Transmission Sprocket 23 Tooth - York 26-0005-23
by York
SKU 19-0488
York #: 26-0005-23
23 tooth front transmission sprocket with a.500 inch offset and 2 holes. For 5 speed models.
Allows the installation of a 180 tire without transmission offset..900 offset is the maximum offset without any modification to the stock inner primary.
- .500inch offset is measured from the back side of the teeth to the back side of the sprocket excluding the flange.
- .940inch offset is measured from the center line of the teeth to the top of the flange on the back side of the sprocket.
- Suggested to use with Pulley Indexing Flange Nut.
| 1991-UP | XLH |
