Shovelhead Ultima Engine Case Set Black - Ultima 206-27 - Big Twin 1970-1984
by Ultima
Original price $979.99 - Original price $979.99
$979.99
7839 ENTRIES 🎟️
$979.99 - $979.99
$979.99
7839 ENTRIES 🎟️
Ultima #: 206-27
Shovelhead Ultima engine case set features a black finish and a 3 piece flywheel design. Engine case features large bore breather for increased crank case vacuum and less blow by.
Set includes main bearings installed chromoly cylinder studs main seal spacer chrome timing hole plug case counterbores for socket head bolts stainless socket head casebolts alignment dowels for true line bore top end feed screen with spring and the oil pressue gauge. Engine case features a 1992-up oil pump and 3.625 inch bore. *NOTE: May require further machining check fit on all related parts.
1970-1984 FL
1970-1984 FX
