S&S Steel Cam Chest Breather Valve Standard - S&S Cycle 33-4241 - OEM 25313-77A - Big Twin 1979-1998
S&S Cycle #: 33-4241 · OEM #: 25313-77A
S&S steel cam chest breather valve is a machined breather valve and gear. Designed to replace stock steel or plastic units.
Features stock duration with standard 1.121 inch outer diameter groove cut along bottom and inchT inch shaped timing mark on gear. Order 8 piece thrust washer set separately.
- Suggested to use with S&S Breather Cam Chest Washer Set.
- Suggested to use with Cam Chest Breather Valve Washer Set.
| 1979-1984 | FL |
| 1986-1998 | FLST |
| 1979-1998 | FLT |
| 1979-1984 | FX |
| 1991-1998 | FXD |
| 1982-1994 | FXR |
| 1984-1998 | FXST |
