Replica 80 Shovelhead Cylinder Piston Kit - V-Twin 11-2604
Replica 80 inch Shovelhead cylinder and piston kit are honed and prefitted with 8:1 compression cast pistons and rings.
Set of two for stock stroke only. They are ready to run and will require break-in. Please refer to proper shop manual for suggestions on break-in. For 1979-1985 Shovelheads. Order gasket set separately. May require the use of a cylinder base nut set available separately. The wrist pin of the piston may require minor honing for proper fitment of the wrist pin. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003.
- Suggested to use with #8601-8 Hi-Torque Cylinder Base Nut Set.
| 1979-1984 | FL |
| 1979-1983 | FLT |
| 1979-1984 | FX |
| 1982-1983 | FXR |
