Primary Chain Tensioner Bracket Kit - V-Twin 18-0783
by York
SKU 18-0783
Chain tensioner kit assembly bolts to the rear motor mount plates on rigid frame models. Kit includes bracket and detent plate.
Chain adjusting shoe assembly is supplied to adjust chain tension. For use with the York Electric Starter Kits. Bracket mounts to the 2 rear engine mount bolts for use with tin inner primary covers only. *NOTE: The inner primary cover must be modified for this conversion.
  • Suggested to use with York Electric Starter Kit.
  • Suggested to use with #32-2039 Electric Starter Kit 4 Speed
1941-1984 FL
