Panhead Engine Case Set - V-Twin 10-1835
Original price $1,939.99 - Original price $1,939.99
$1,939.99
15519 ENTRIES 🎟️
$1,939.99 - $1,939.99
$1,939.99
15519 ENTRIES 🎟️
Panhead engine case set includes tapered bearing assembly for left side and case race on right side. Features a front saddle for the 3 brush generator strap.
Accepts shovel head OHO line to the heads. Set does not accept cast inner cover for 1965-1969 FL models. *NOTE: 3 brush generator saddle may be removed for 2 brush generator installation. Case cylinder ports are 3.8750 inch and machined to fit 3-5/8 inch cylinders with drain notch. May be fitted with a tin inner primary cover. Bore to fit Y oil line.
  • Suggested to use with 3-5/8inch Cylinder Set.
1958-1969 FL
