Kick Starter Conversion Kit Alloy Finish - V-Twin 22-0458 - Sportster 2007+
Kick starter conversion kit includes alloy finish sprocket cover with transmission mainshaft kick starter arm rubber pedal and kick shaft. Includes alloy cover that features a natural finish. Fits 5-speed models.
Kick Starter Kit includes main shaft with integral gear set one piece forged construction as OEM. Also includes kick start cover kick gear assembly and transmission main shaft that features a natural finish. Kicker arm and rubber pedal feature a chrome finish. Note: Must use with forward controls or relocation of master cylinder. Electric starter is retained. Kicker cover is milled out to allow use of original exhaust bracket. Unique design has kicker gear mounted on the side of the pulley for easy access. Installation requires disassembly of the transmission to replace the mainshaft. The motor case must be split for installation. Mechanical and technical expertise required.
| 2007-UP | XL |
