Jims Piston Ring End Gap Tool - Jims 3200 - Twin Cam 1999+
by Jims
SKU 16-3200
$109.99
$109.99 - $109.99
$109.99
Jims #: 3200
Tool makes measuring ring end gap faster and more accurate.
Jims pison ring end gap tool makes measuring ring end gap faster more accurate and will eliminate guess work. The flanged design allows the piston ring to fit squarely in the cylinder bore every time. This is the first tool that is designed to test oil ring gaps by propriety cutout feature. Just install any ring top 2nd or oil control rails on the tool. Install tool into a cylinder bore and then view the ring end gap in the inchkey slot inch. Use a feeler gauge to get your end gap measurement. Each side of the tool is made for checking standard size piston rings. Fits Twin Cam standard size pistons for 95 inch 103 inch or 110 inch with 3.875 inch or 4.00 inch bore.
  • Install tool into cylinder bore and view the ring end gap in the Key Slot. Use a feeler gauge to get your end gap measure.
1999-2017 FLST
1999-UP FLT
1999-2017 FXD
1999-2017 FXST
