Jims M8 Camshaft Needle Bearing Remover and Installer - Jims 5806 - Twin Cam 2017+
by Jims
SKU 16-1185
$379.99
3799 ENTRIES 🎟️
$379.99 - $379.99
$379.99
3799 ENTRIES 🎟️
Jims #: 5806
Jims camshaft needle bearing remover and installer tool is required for correct and accurate replacement of the camshaft inner needle bearing for M8 models.
This tool holds tighter tolerances which allows for a more precise installation depth. *NOTE: This remover uses the inchJims Style inch remover collet as well as inchJims inch fine threaded installation driver. A new removal holes works as a window to let you see what you're doing while using the tool.
2018-UP FLST
2017-UP FLT
2018-UP FXST
