Jims Ignition Switch and Fork Lock Tool - Jims 778 - Twin Cam Dyna 2017-2017
by Jims
SKU 16-1179
899 ENTRIES 🎟️
899 ENTRIES 🎟️
Jims #: 778
Used to make installing or removing the ignition switch and fork lock a easy process.
Locates on the ignition switch face nut that holds the switch in place on the frame and lets you remove or install this switch correctly. Tool has a 3/8 inch drive access hole.
| 2017 | FXD |
