Daytona Twin Tec Internal Ignition Kit - Daytona Twin Tech 3005
Daytona Twin Tech #: 3005
Twin Tec internal ignition has a billet aluminum housing with wide timing advance adjustment range which accommodates stock to highly modified engines.
With this ignition you are able to select single or dual fire mode and multi spark mode for quick starting and a smooth cruise. RPM limit can be set digitally at 100 RPM steps and has coil outputs to protect against short circuits. This ignition is intended for electric start applications and includes ignition coil and wire set.
| 1970-1984 | FL |
| 1986-1999 | FLST |
| 1980-1999 | FLT |
| 1970-1984 | FX |
| 1991-1999 | FXD |
| 1982-1994 | FXR |
| 1984-1999 | FXST |
| 1971-2003 | XL |
