Clutch Drum Kit - V-Twin 18-0130 - Evolution 1985-1990
Kit features stock style components for a complete clutch installation.
Includes adjuster jam nut left side pushrod adjuster clutch hub key and nut clutch hub with steel center drum spring clutch pressure plate adjuster plate release plate snap ring transmission main shaft bearing clutch drum retaining ring clutch pressure plate snap ring clutch set steel clutch plate set bolt kit 5-speed clutch pushrod kit.
| 1986-1990 | FLST |
| 1985-1990 | FLT |
| 1985-1990 | FXR |
| 1985-1990 | FXST |
