Chrome Extended Forward Control Conversion Kit - Wyatt Gatling 77531 - Sportster 2011+
$119.99
1199 ENTRIES 🎟️
$119.99 - $119.99
$119.99
1199 ENTRIES 🎟️
Wyatt Gatling #: 77531
+2 inch forward control footpeg conversion kit is for use with forward controls that no longer allow the fitting of standard driver footpegs. This kit lets you mount standard footpegs on the late model forward controls.
Kit includes a left and right footpeg mount with mounting hardware. Also works as replacement footpeg mounts on select OEM and V-Twin forward control kits. *NOTE: If converting standard forward controls to extended a longer shifter linkage rod (10-1/4 inch long) is also required available separately or use the 2 inch extension along with the original linkage rod.
  • Required to use with Chrome Straight Shifter Rod 10-1/2inch Long if converting standard forward controls to be extended.
  • Required to use with Shifter Rod Extension Chrome along with the original linkage rod if converting standard forward controls to be extended.
2011-UP XL
