Bastardo Overhead Valve Oil Line Set Stainless Steel - V-Twin 40-0760
Three 5 inch braided stainless steel Bastardo oil lines.
Requires one male T brake hose adapter fitting and three straight brake hose adapter fittings. Two oil lines connect from heads to T fitting. Additional line runs from bottom of T to crank case. For Overhead oiling systems as supplied on our Basterdo motors.
- Required to use with Brake Hose Adapter Fitting Male Tee
- Required to use with Brake Hose Adapter Fitting Straight
| 1963-1969 | FL |
