Barnett M8 Scorpion Clutch Kit - Barnett 608-30-10017 - Milwaukee-Eight 2018+
Barnett #: 608-30-10017
Kit features over twice as much friction surface area compared to stock clutch. For M8 models.
Scorpion clutch provides a positive engagement and release. Scorpion clutches incorporate 6 heavy duty coil springs. In addition an extra spring set with a different spring rate is included which allows the clutch to be tuned for street or race application depending on usage. Tunability is easy without removal of the primary cover. Barnett Friction Plates are compatible with any primary oil. Kit is designed to be used with stock type clutch basket.
| 2021-UP | FLT |
| 2018-UP | FXST |
