84 Tooth Clutch Drum Ring Gear Kit - York 148180 - Big Twin 1998-2006
by York
SKU 18-0366
$139.99
$139.99
$139.99
$139.99
$139.99
$139.99
York #: 148180
Kit includes a 84 tooth ring gear with mounting hardware and a 10 tooth pinion gear.
This ratio allows more RPMs for easier starting. The heavier teeth configuration is less susceptible to wear or breakage by converting the 102 tooth ring gear to 84 tooth.
- Inner Diameter: 6-3/8 inches
- 10T Pinion Gear O.D.: 1.244 inches
- 84T Gear O.D.: 8-1/2 inches
| 1998-2006 | FLST |
| 1998-2006 | FLT |
| 1998-2005 | FXD |
| 1998-2006 | FXST |
