18 x 4.25" Rear Spoke Wheel - V-Twin 52-0115
Replica 18 inch X 4.25 inch star hub type rear wheel kit includes a chrome hub chrome drop center rim cadmium spokes and rubber rim strip.
*Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. *NOTE: The valve stem hole is on the star side of the hub and measures 3/16 inch from the drum side flange.
- When looking at the star side of the wheel the inner layer of spokes should point clockwise.
- Lay straightedge across brake side spoke flange of hub and measure distance from straight ede to rim. Measures 1/4inch when rim is correctly centered.
| 1936-1940 | EL |
| 1941-1966 | FL |
| 1937-1948 | UL |
| 1936-1952 | WL |
