18 x 2.15" WR Front Spool Wheel Black - V-Twin 52-0013
18 inch x 2.15 inch WR spool wheel features a nickel plated hub stainless steel spokes and nipples and an 18 inch black steel rim. Also includes retro ball bearings and uses 7/16 inch stock axle to fit 45 inch Spring Fork rockers.
Rim is 40 spoke 18 inch x 2.15 inch black steel rim that is laced and trued. Center tube of hub measures to be 6.5 inch. The stainless steel spokes have a diameter of 3.75mm. Wheel hub has a 3/8 inch inner diameter. The inner diameter without the bearing is 3/4 inch. Ball bearings are installed. 45 spring forks are 6-1/2 inch between the rockers. The rockers are mounted on the inside of the spring fork. Order 7/16 inch axle separately. *NOTE: Wheels accept metal stem inner tubes.
- Required to use with Chrome Spacers 3/8inch X 3/4inch X 3/4inch
- Suggested to use with 7/16inch-20 Front Axle
| 1941-1952 | WR |
