18 x 2.15" WR Front Spool Wheel Alloy - V-Twin 52-0014
18 inch x 2.15 inch WR spool wheel features a nickel plated hub stainless steel spokes and nipples and an 18 inch polished alloy H-C type rim. Also includes retro ball bearings and uses 7/16 inch stock axle to fit 45 inch Spring Fork rocke
Wheel hub has a 3/8 inch inner diameter. Ball bearings are installed. 45 spring forks are 6-1/2 inch between the rockers. The rockers are mounted on the inside of the spring fork. Order 7/16 inch axle separately. *NOTE: Wheels accept metal stem inner tubes.
- Width: 2.15 inches
- Required to use with Chrome Spacers 3/8inch X 3/4inch X 3/4inch
- Suggested to use with 7/16inch-20 Front Axle
| 1937-1952 | WR |
