Sifton Countershaft Nut Sprocket Tool - Sifton 97-420 - OEM 94660-37A
by Sifton
$109.99
1099 ENTRIES 🎟️
$109.99 - $109.99
$109.99
1099 ENTRIES 🎟️
Sifton #: 97-420 · OEM #: 94660-37A
Sifton center nut wrench tool is a heavy duty thick wall tube extra long. Tool has a 2 piece design a inner collar will retain the wrench to the nut for safer service work.
Fully machined hex wrench includes centering collar which has ID threads to fit mainshaft. Hex tool and collar is machined from bar stock and heat treated to 43 degrees HRC. This tool is able to accept 1/2 inch drive ratchet or breaker bar. *NOTE: Socket machined from solid steel!
1941-1984 FL
1986-2006 FLST
1979-2006 FLT
1971-1984 FX
1991-2005 FXD
1982-1994 FXR
1986-2006 FXST
1991-UP XL
