Kick Starter Cover Stud Set - V-Twin 17-1489 - OEM 33298-36
OEM #: 33298-36, 2134-36
Kick starter cover stud set is white zinc plated as original use with parkerized nut and washer set.
This is a 9 piece set. *NOTE: Studs for installation to protrude 7/8 inch from face of transmission case. *NOTE: Nut and washer sets available separately. *NOTE: Later model applications 1960's - 1970's use zinc plated studs as original. *NOTE: Apply loctite on 5/16 inch-18 threads that go into transmission case.
| 1936-1952 | EL |
| 1941-1964 | FL |
