Speedometer Drive Gear 7 Tooth - V-Twin 17-0094 - OEM 35635-69
359 ENTRIES 🎟️
359 ENTRIES 🎟️
OEM #: 35635-69
7 tooth speedometer drive gear.
For use with 23 tooth speedometer drive unit. *NOTE: 66.5mm outer diameter for case clearance and fit.
  • Outer Diameter: 66.50mm
  • Inner Diameter: 55.58mm
  • Thickness:.315 inches
  • Suggested to use with 23 Tooth Speedometer Drive Unit.
1969-1980 FL
1969-1980 FLH
