6-Speed Reverse Gear Kit - V-Twin 17-0296 - Twin Cam 2006+
Original price $479.99 - Original price $479.99
$479.99
3839 ENTRIES 🎟️
$479.99 - $479.99
$479.99
3839 ENTRIES 🎟️
6-speed reverse gear kit includes a safety engine shut-off switch to prevent damage in case the forward gears are engaged. The engagement handle is adjustable. For use on models listed with cable operated clutch mechanism only.
Reverse gears are a must for Trikes. The main body is machined from aircraft grade aluminum and the gears are hardened steel for long life.
2007-UP FLST
2006-UP FLT
2006-2017 FXD
2007-UP FXST
