4-Speed Big Twin Transmission Assembly - V-Twin 17-1288
1970-1978 FL transmission is fully assembled and includes 22 tooth countershaft sprocket and chrome clutch arm. Assembly is for use with forward controls and/or footboards.
Replica 4-speed transmission with a 3.00 ratio features cast case and internal parts polished kicker cover and components clutch rod throwout bearing natural finish ratchet top with chrome dust cover chrome arm mount studs hub nut seal and key. Cases have mount lugs to accept aluminum inner primary covers. Speedometer drive gear is supplied and has a 1:1 ratio. Torrington needle bearings are used throughout. No Manufacturer's Statement of Origin required Bill of Sale only.
| 1970-1978 | FL |
