4-Speed Big Twin Transmission Assembly - V-Twin 17-0026
1941-1964 FL transmission assembly features cast kick cover with a one piece black kick starter arm. Assembly includes parkerized clutch arm and adjuster bolt.
Transmission is ratchet type and includes original cast case with early style main drive gear 44 rollers and 2:1 ratio speedometer drive gear internal parts aluminum kicker cover and components clutch rod throwout bearing ratchet top with natural finish with chrome dust cover early 1 piece black arm for kick start only mount studs seal and key. Transmission features a 3.00 ratio FL style gears. No Manufacturer's Statement of Origin is required Bill of Sale only. Transmission accepts 2:1 ratio speedometer. Includes a parkerized clutch arm and a parkerized clutch release arm. *NOTE: All transmissions are fitted with a 22 tooth countershaft sprocket (V-Twin ). One piece is an accurate look for 1941-1953 FL models. This is great for Bobbers Period Choppers or semi-restoration builds.
| 1936-1952 | EL |
| 1941-1964 | FL |
