Replica 3-Hole Crank Pin - Eastern A-23960-29A - OEM 23960-29
by Eastern
$109.99
$109.99
$109.99
1099 ENTRIES 🎟️
$109.99
$109.99
$109.99
1099 ENTRIES 🎟️
Eastern #: A-23960-29A · OEM #: 23960-29, 348-29
Replica crank pin with 3 holes are made of 8620 steel.062 heat penetration.
*NOTE: Check technical notes before ordering. The distance measured from the edge not including threads is 2.516 inch.
- Must align oil feed in flywheels with crank pin. OEM used 2 different flywheels so hole locations may be different. Oiling hole is 54° away from keyway
| 1937-1973 | G |
| 1937-1952 | WL |
