Left Side UL Engine Case - V-Twin 10-0879 - OEM 24536-37
OEM #: 24536-37, 410-37, 406-37
Side valve replacement left side engine case features a blank number boss. This case has the same oil passage for the outside sprocket shaft bearing as the original case.
NOTE: Left side case must be fitted to existing OE right side case. Cylinder base surfaces and motor mount surfaces must be milled to match before assembly. *NOTE: Requires hole to be drilled in the left case. Cast in the bushing after the case race has been pressed in. Install the race and then drill the hole. *NOTE: Left side cases accept standard case race.
- Suggested to use with Sprocket Left Side Case Race Standard.
| 1937-1948 | UL |
